StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier
Quicklinx: 7P2JWS00 Mfr#: ST122HDMI2
£69.74 ex VAT
£83.68 inc VAT
Split an HDMI audio and video signal to two displays simultaneously.
The ST122HDMI2 2-Port High Speed HDMI Splitter and Signal Amplifier lets you share a single HDMI source signal with audio between two HDMI or DVI (using HDMI to DVI adapter) enabled displays simultaneously.
Supporting True HD 1080p video resolutions, the HDMI splitter acts as a distribution amplifier that enables you to situate your HDMI-capable displays up to 50ft (15m) away from the splitter, and features 3.5mm audio connections, giving you the option of sending your accompanying audio signal through the HDMI cable, or through a separate channel.
The HDMI splitter is easy to install and use with no software or configuration required, for a completely plug-and-play setup that can be used with HDMI output devices such as Blu-ray players or desktop/laptop computers.
StarTech.com HDMI Splitter 1 In 2 Out - 1080p - 2 Port - Signal Amplifier - Rugged - HDMI Multi Port - HDMI Audio Splitter (ST122HDMI2) - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Ports
2 x HDMI
HDCP compliant
AC 120/230 V
8 cm x 18 cm x 1.9 cm
0.5 kg
3-year warranty
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
1080p
HDCP compliant
2 x HDMI output , 1 x HDMI input , 1 x audio input mini-jack , 2 x audio output mini-jack
External power adapter
AC 120/230 V
FCC, RoHS
8 cm
18 cm
1.9 cm
0.5 kg
Limited warranty - 3 years
0 - 80%
7P2J StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
7P2J StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
7P2J StarTech.com 2 Port DVI Video Splitter with Audio In Stock £89.33
7P2J StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
7P2J StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
7P2J StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
7P2J StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £91.53
7P2J StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier In Stock £69.74
7P2J StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
7P2J StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £50.75
7P2J StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
7P2J StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
7P2J StarTech.com 8-Port 4K 60Hz HDMI Splitter In Stock £133.22
7P2J StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £55.73
