StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support
Quicklinx: 7NXXWS00 Mfr#: ECUSB3S254F
Select:
  • Windows 8 (32/64 bits)
£26.99 ex VAT
£32.38 inc VAT
Add two flushmount USB 3.0 ports to your ExpressCard-enabled laptop. The ECUSB3S254F 2-Port Flush Mount USB 3.0 ExpressCard Adapter lets you add two USB 3.0 ports to your ExpressCard-enabled laptop.
The USB 3.0 card uses a unique design that allows it to sit flush in a standard 54mm laptop ExpressCard slot, creating a seamless add-on that can be left installed even while on the move, without having to worry about impact damage to either the card or the ExpressCard slot.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
The SuperSpeed USB 3.0 Card supports data transfer rates of up to 5Gbps, and is backward compatible with USB 2.0 (at up to 480Mbps), or USB 1.1/1.0 at up to 12/1.5 Mbps respectively - the perfect laptop accessory for users to connect USB devices, both new and old.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
  • Improved Performance with UASP
    UASP is supported in Windows 8 and Server 2012. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.2 Gen 1 at peak performance. At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources. Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.2 Gen 1 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP - Dual Port Laptop ExpressCard USB 3 Controller (ECUSB3S254F) - USB adapter - ExpressCard - USB 3.0 x 2
USB adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
USB 3.0 x 2
7.4 cm x 5.4 cm x 0.5 cm
24 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
1 x NEC µPD720200
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
1-year warranty
P/N: S2510BMU33, S2510BPU33, S2510BPU337, S2510BU33PW, S251BMU3FP, S251BU31315, S3510BMU33, S3510SMU33, S3540BU33E, SM2NGFFMBU33, ST7300USB3B, UNI251BMU33, USB31000NDS, USB31000S, USB31000SW, USB3S2SAT3CB
USB adapter
Plug-in module
ExpressCard/34
Ports
USB 3.0 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
1 x NEC µPD720200
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x ExpressCard/34
FCC, RoHS
Software Included
Drivers & Utilities
7.4 cm
5.4 cm
0.5 cm
24 g
Limited warranty - 1 year
85 °C
7NXX StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
