Add 2 USB 3.0 Ports to a Laptop through an ExpressCard Slot. The ECUSB3S22 2-Port ExpressCard USB 3.0 Card adds 2 SuperSpeed USB 3.0 ports to an ExpressCard-enabled computer system, using a 34mm form factor that will fit in both 34mm and 54mm slots, along with ports mounted side-by-side for easy access.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
USB 3.0 supports data transfer rates up to 5 Gbps (10x faster than USB 2.0) and is able to provide more power per port, to help support faster and more powerful devices. Also, this ExpressCard adapter is backward compatible with USB 2.0/1.x, so all of your existing devices will still work.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
- StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP - USB 3.0 Controller - USB 3.0 ExpressCard - USB 3.0 Adapter (ECUSB3S22) - USB adapter - ExpressCard - USB 3.0 x 2
- USB adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- ExpressCard/34
- Ports
- USB 3.0 x 2
- 3.4 cm x 11.5 cm x 1.3 cm
- 32 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- 1 x NEC µPD720200 µPD720200
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- 2-year warranty
- Designed For
- P/N: HBS304A24A, S2510BU33PW, S251BMU3FP, S3510BMU33, S3510SMU33, ST103008U2C, ST3300GU3B, ST3300U3S, ST4300U3C1, ST4300U3C1B, ST4300U3C3, ST53004U1C, ST7300U3M, ST7300USB3B, ST7300USBME, ST93007U2C, USB221SS, USB31000NDS, USB31000S, USB31000S2H, USB31000SA, USB31000SW, USB3S2SAT3CB
- USB adapter
- Form Factor
- Plug-in module
- ExpressCard/34
- Ports
- USB 3.0 x 2
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
Processor / Memory
- Processor
- 2 x USB 3.0 - 9 pin USB Type A
- Compatible Slots
- 1 x ExpressCard/34
- FCC, RoHS
- OS Required
- 3.4 cm
- 11.5 cm
- 1.3 cm
- 32 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 60%
- Designed For
StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.21 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £24.13 |
StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M | In Stock | £6.21 |
StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.79 |
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £5.12 |
StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B | In Stock | £5.94 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £22.95 |
