StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support
Quicklinx: 7W8DWS00 Mfr#: ECUSB3S22
Type: USB adapter
Compatibility: PC
Interface: ExpressCard/34
10 in stock
£22.95 ex VAT
£27.54 inc VAT
Add 2 USB 3.0 Ports to a Laptop through an ExpressCard Slot. The ECUSB3S22 2-Port ExpressCard USB 3.0 Card adds 2 SuperSpeed USB 3.0 ports to an ExpressCard-enabled computer system, using a 34mm form factor that will fit in both 34mm and 54mm slots, along with ports mounted side-by-side for easy access.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
USB 3.0 supports data transfer rates up to 5 Gbps (10x faster than USB 2.0) and is able to provide more power per port, to help support faster and more powerful devices. Also, this ExpressCard adapter is backward compatible with USB 2.0/1.x, so all of your existing devices will still work.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP - USB 3.0 Controller - USB 3.0 ExpressCard - USB 3.0 Adapter (ECUSB3S22) - USB adapter - ExpressCard - USB 3.0 x 2
USB adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
USB 3.0 x 2
3.4 cm x 11.5 cm x 1.3 cm
32 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
1 x NEC µPD720200
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
P/N: HBS304A24A, S2510BU33PW, S251BMU3FP, S3510BMU33, S3510SMU33, ST103008U2C, ST3300GU3B, ST3300U3S, ST4300U3C1, ST4300U3C1B, ST4300U3C3, ST53004U1C, ST7300U3M, ST7300USB3B, ST7300USBME, ST93007U2C, USB221SS, USB31000NDS, USB31000S, USB31000S2H, USB31000SA, USB31000SW, USB3S2SAT3CB
USB adapter
Plug-in module
ExpressCard/34
Ports
USB 3.0 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
1 x NEC µPD720200
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x ExpressCard/34
FCC, RoHS
3.4 cm
11.5 cm
1.3 cm
32 g
50 °C
0 - 60%
7W8D StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.21
7W8D StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £24.13
7W8D StarTech.com 6 ft Black SuperSpeed USB 3.0 Cable A to A - M/M In Stock £6.21
7W8D StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to B - M/M In Stock £5.12
7W8D StarTech.com 1 ft SuperSpeed USB 3.0 Cable A to Micro B In Stock £5.96
7W8D StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £22.95
Type: USB adapter
Compatibility: PC
Price Range Ex VAT: 0 - 50
