StarTech.com 2-port Dual VGA KVM Switch
Quicklinx: BGBXWS00 Mfr#: SV231DVGAU2A
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 2
Hurry, only 1 left in stock!
£67.05 ex VAT
£80.46 inc VAT
Access two dual-video computers and two shared USB peripherals from a single workstation. This USB KVM lets you connect two computers, each with dual VGA outputs, to a dual-monitor workstation. You can switch the workstation between each computer, as well as two additional USB peripheral devices and 3.5mm speakers & microphone.
With support for two VGA video inputs and two different computers, this KVM switch maximizes productivity. Not only can you access multiple computers, but you can also use two VGA monitors on each computer streaming independent content to each display, which gives you the freedom to multitask and increase your productivity. The VGA ports support resolutions up to 1920x1200 for maximum screen viewing space.
Featuring dual video and support for your keyboard and mouse, along with a 2-port USB hub for two additional peripheral devices, this KVM switch is perfect for accessing two separate systems using the same workstation. Support for your workstation plus two additional peripheral devices makes this KVM ideal for server control, simplifying access to multiple computer systems.
This 2-port KVM ensures effortless operation with intuitive hotkey control. It provides a simple yet comprehensive solution for switching between each connected computer and also supports manual operation using the easy-to-access buttons located on the front of the switch.
StarTech.com 2 Port VGA KVM Switch - Dual VGA - Hot-key & Audio Support - 1920x1200 KVM Switch - KVM Video Switch (SV231DVGAU2A) - KVM / audio / USB switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
AC 120/230 V
22 cm x 13 cm x 6 cm
1.236 kg
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Status Indicators
Power, status
2 x VGA output HD-15 , 1 x audio output mini-jack , 1 x microphone output mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 2 x USB 2.0 Type A , 4 x VGA input HD-15 , 2 x microphone input mini-jack , 2 x audio input mini-jack , 2 x keyboard (USB) / mouse (USB) Type B
External power adapter
AC 120/230 V
FCC, RoHS
22 cm
13 cm
6 cm
1.236 kg
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
BGBX StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £81.83
BGBX StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £233.24
BGBX StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £128.11
BGBX StarTech.com DisplayPort USB KVM Switch In Stock £287.60
BGBX StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
BGBX StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.48
BGBX StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.48
BGBX StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.06
BGBX StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M In Stock £4.42
BGBX StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.78
BGBX StarTech.com 6 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M In Stock £3.75
BGBX StarTech.com 6 ft 4-in-1 USB VGA KVM Switch Cable with Audio and Microphone In Stock £6.48
BGBX StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
BGBX StarTech.com DC Power Adapter - 12V, 2A In Stock £11.68
BGBX StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
BGBX StarTech.com 4 Port HDMI KVM Switch - 4K 30Hz - Dual Display In Stock £469.52
Connectivity: KVM
Ports: 2
