StarTech.com 2 Port DP USB C KVM Switch
Quicklinx: H242WS00 Mfr#: SV231DPUCA
Type: KVM / audio / USB switch
Ports: 2
Connectivity: KVM
£198.92 ex VAT
£238.70 inc VAT
This 2-port KVM switch combines 4K 60Hz capabilities with control of two USB-C DP Alt-mode, Thunderbolt 3, or Thunderbolt 4 computers.
  • 4K 60Hz Resolution
    This 2-Port USB-C KVM switches between two USB-C enabled computers viewed over a single DisplayPort monitor. It supports up to 4K 60Hz (4:4:4) resolutions with 2x USB-A 480Mbps hub ports. This KVM is ideal for applications such as CAD/CAM, video editing, and content creation. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Analog and Digital Audio
    This USB-C DisplayPort KVM Switch supports 2-channel analog and digital audio output, as well as microphone input, through 3.5mm or USB ports. This provides the user with centralized audio control through the KVM switch. Audio profiles are selectable with hot key commands.
  • Intuitive Control
    The front panel push button and hot key functions make it easy to switch between computers. Install host computers using a single USB-C cable to connect to the KVM. USB HID and USB Hub ports on the front and rear ensure convenient setup configuration and access to USB peripherals. The metal housing of the KVM Switch is suitable for many installation environments. This product is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
StarTech.com USB C KVM Switch, 2 Port DisplayPort KVM w/ 4K 60Hz UHD HDR Video, 3.5mm Audio, USB Type C KVM Switch, 4x USB HID and 2x USB A 3.2 Gen 1 5Gbps Hub, Thunderbolt 3/4 Compatible - Hot Key Switching (SV231DPUCA) - KVM / audio / USB switch - 2 ports - TAA Compliant
Subtype
KVM
Ports
2 x KVM / audio / USB
Auto Scan Mode, metal housing, Pushbutton/Hotkey switching, HDR 4K60 4:4:4 compatible, 4K UHD video streaming, USB HID Transport, 2.1 channel audio support, video mode switch
USB 1.1, HDCP 2.2, USB 3.2 Gen 1
AC 100-240 V 1.2 A
14 cm x 16 cm x 4 cm
600 g
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
Keyboard / Mouse Interface
USB
Max Resolution
4K @ 60 Hz
Status Indicators
Select
1 x DisplayPort output , 2 x USB 3.2 Gen 1 Type A , 4 x USB 1.1 Type A , 2 x USB Type C host , 1 x headphones mini-jack , 1 x microphone mini-jack
External power adapter
Power Provided
DC 12 V - 3 A
AC 100-240 V
Electric Current Required
1.2 A
Rubber feet set
MTBF
158,000 hours
FCC Part 15, RoHS, WEEE, RCM, Thunderbolt 3, Thunderbolt 4, DisplayPort 1.2 (Alt Mode)
TAA Compliant
14 cm
16 cm
4 cm
600 g
Shipping Width
18.4 cm
Shipping Depth
23.8 cm
Shipping Height
8.9 cm
Shipping Weight
1 kg
Limited warranty - 2 years , Technical support - assistance - lifetime
0 - 80% RH
Min Storage Temperature
-10 °C
Max Storage Temperature
60 °C
H242 StarTech.com 2 Port USB C KVM Switch In Stock £77.13
H242 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.40
H242 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
H242 StarTech.com 3ft USB C Cable 10Gbps Gen2 In Stock £15.19
H242 StarTech.com 20" USB C Cable 10Gbps Gen2 In Stock £13.14
H242 StarTech.com 2 Port Hybrid USB-C KVM Switch In Stock £34.40
H242 StarTech.com USB-C KVM Switch, 4K 60Hz In Stock £150.27
Ports: 2
Connectivity: KVM
