StarTech.com 2 Port Black USB KVM Switch Kit with Audio and Cables
Customer rating: 5.0* (Write a review)
Quicklinx: 4JDHWS00 Mfr#: SV211KUSB
Type: KVM / audio switch
Ports: 2
Connectivity: KVM
25 In Stock
£22.25 ex VAT
£26.70 inc VAT
Control 2 USB-enabled computers from a single keyboard, mouse and monitor; includes all-in-one cables. The SV211KUSB 2 Port USB KVM Switch Kit with Audio and Cables lets you control two USB-enabled computers using a single keyboard, mouse and VGA monitor and offers both hotkey and top panel push-button operation for simple switching between connected computers.
Designed to integrate seamlessly into any environment, the USB KVM switch offers a small footprint design (roughly the size of a deck of playing cards) and draws power from the connected computers, so it doesn''t require an external power supply.
A suitable solution for virtually any application, the USB KVM switch supports video resolutions of up to 2048 x 1536 as well as audio switching. The USB KVM switch includes two 4ft 2-in-1 VGA and USB Host Cables, providing everything needed for quick installation to provide a complete, out-of-the-box KVM solution.
The KVM switch is delivering dependable and convenient control of multiple computers from a single peripheral station.
  • Efficient video performance
    The KVM switch supports video resolutions up to 2048 x 1536 at 60Hz, ensuring crisp and clear images for users across both connected computing devices.
  • Versatile connectivity options
    With USB connections for keyboard and mouse, as well as audio support, this KVM switch integrates multiple functionalities into one compact solution.
  • Simple hot-key switching
    Users can switch between connected systems effortlessly using hot-keys, making the transition smooth and efficient without needing to physically manage cables.
  • Compact desktop design
    Its compact form factor makes it easy to integrate into various settings, whether at home or in an office environment, requiring minimal space.
  • Compliance with standards
    This KVM switch is compliant with FCC standards, ensuring reliable performance and safety during use.
StarTech.com 2 Port USB VGA KVM Switch - Single VGA - Hot-key & Audio Support - 2048x1536 @60Hz KVM Switch - KVM Video Switch (SV211KUSB) - KVM / audio switch - 2 ports
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
6 cm x 9.6 cm x 2 cm
200 g
Brown
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Status Indicators
Port status
2 x KVM HD-15 , Audio: 2 x USB - mini-USB Type B , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x microphone mini-jack , 1 x audio input mini-jack
Brown
2 x video / USB cable - 1.2 m , 2 x audio / USB cable - 1.2 m
FCC
Software Included
Drivers & Utilities
6 cm
9.6 cm
2 cm
200 g
4JDH StarTech.com 2 Port Black USB KVM Switch Kit with Audio and Cables In Stock £22.25
4JDH StarTech.com 4 Port Black USB KVM Switch Kit with Cables and Audio In Stock £60.35
4JDH StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £81.83
4JDH StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £83.26
4JDH StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £91.46
Customer reviews
Write a review for the StarTech.com 2 Port Black USB KVM Switch Kit with Audio and Cables here!
Works fine
Reviewed by Steve. Review Posted 25/03/2009
Delivered promptly and on time. Everything was in the box as stated and it was very simple to install. I ran the software CD on both PCs (Vista) and the little switcher programme installed without difficulty. Plugging in the cables was straightforward and obvious - the diagram in the instruction booklet was clear and unambiguous. Operation is also simple. You end up with an icon on the taskbar showing either '1' or '2' depending on which computer you are currently working on. Switching is straightforward: hit scroll lock twice and that's it, along with the usual dee-dum USB noise/alert. You can also switch using the buttons on the little box itself but I've not bothered. The software (Windows-only) gives you some other options but I've not bothered with it since installation. A good bit of kit!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
EDImax/StarTech 2 port KVM
Reviewed by Open PC. Review Posted 19/11/2008
This is being sold under the EDImax and StarTech brands. One is cheaper, so buy that one...
As mentioned by another reviewer, works fine with a USB keyboard and mouse that uses one USB dongle (connected into KVMs USB keyboard connector).
When you select one PC, the other sees the USB keyboard & mouse disappear. Similarly the selected PC sees them appear. i.e. hot plug will occur & associated pop up notifications.
  • Overall 5*
  • Ease of use 5*
Great product
Reviewed by Sam Thompson. Review Posted 10/10/2008
Pretty good product. Does exactly what it says on the box. In case anyone is wondering, you don't need a USB mouse & USB keyboard together - it is possible to have a single USB dongle which (wirelessly) connects to a mouse and a keyboard. To get your machine to display its correct resolution on boot, just make sure your KVM box is set to receive input from your booting machine.
A couple of minor quibbles: using virtualisation software (such as VMware or Virtual PC) can be problematic. Just be sure to unplug the USB cable from your alt computer (ie. the one not running the virtualisation software). Also, if I was being really picky, in Windows 9x/XP/Vista, during switching machines, you do get that "dee-dum , dee-dum" (USB removed/detected) noise.
  • Overall 4*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Ports: 2
Connectivity: KVM
