Control up to 4 PC or Mac computers from a single keyboard, mouse and monitor and share any USB device between all connected computers. The SV431USB 4 Port rack mountable VGA USB KVM Switch with Hub offers simple control of up to four computers from a single monitor/display and USB peripheral set (keyboard, mouse).
The USB KVM switch features an integrated 4 port USB hub, allowing you to share connected USB peripherals between the four controlled PC/Mac computers as though the devices were connected directly.
Offering convenient placement and installation options, the KVM switch features a 1U rack-mountable form factor and rear port connection to master and slave computers, allowing you to make the necessary device connections without disrupting your workspace.
A cross-platform solution, the KVM switch supports high resolution applications at up to 1920x1440 and provides a smooth operating experience when controlling mixed (Windows/Mac OS/Linux) environments.
- StarTech.com 4 Port Professional VGA USB KVM Switch with Hub - 1U Rack-mountable KVM Switch (SV431USB) - KVM switch - 4 ports
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Users Qty
- 1 local user
- 22 cm x 13 cm x 4.4 cm
- 0.9 kg
- Black
- 3-year warranty
- Designed For
- P/N: SV431RACK, SVUSB2N1_10, SVUSB2N1_15, SVUSB2N1_6
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 4 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- Status Indicators
- Port status, power
- 4 x USB Type B , 4 x VGA HD-15 , 1 x VGA HD-15 , 2 x USB Type A
- Black
- Rack Mounting Kit
- Optional
- 22 cm
- 13 cm
- 4.4 cm
- 0.9 kg
- Limited warranty - parts and labour - 3 years - carry-in
- Designed For
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £8.74 |
StarTech.com 10 ft 2-in-1 Universal USB KVM Cable | In Stock | £12.47 |
StarTech.com 4 Port Black USB KVM Switch Kit with Cables and Audio | In Stock | £61.85 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £83.88 |
StarTech.com Spare 5V DC UK Power Adapter for SV231USB & SV431USB | In Stock | £8.36 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.32 |
StarTech.com 15 ft 2-in-1 Universal USB KVM Cable | In Stock | £17.46 |
