StarTech.com 2-Bay 2.5 SATA SSD / HDD Rack
Quicklinx: D72NWS00 Mfr#: HSB225S3R
Accessory Type: HDD Enclosure
£44.72 ex VAT
£53.66 inc VAT
Easily connect and hot swap two 2.5 in. SATA hard drives or SSDs through a single 3.5 in. front bay. This HDD rack lets you install two 2.5" SATA hard drives or solid-state drives into a single 3.5" front bay. With configurable RAID support, the SATA drive rack provides an ideal data storage solution.
Configure and arrange your drives for increased drive capacity, performance, or data redundancy, with built-in RAID functionality. With multiple RAID options, such as RAID 0, RAID 1, spanning, or JBOD, you can build the data storage solution that works best for you.
This SATA backplane is trayless and hot-swappable, which makes it easy to install and remove your drives from your computer system when required, without having to open the case every time. It also provides a more convenient way to create backups for data recovery and archiving.
The removable hard-drive bay/backplane features durable aluminum construction for long-lasting performance. The SATA backplane also has LED indicators for power and hard drive activity, and drive status, which makes it easy to monitor the status of your hard drives and RAID array.
StarTech.com 2.5" SATA SSD / HDD Mobile Rack - Hot Swap Trayless Mobile Rack - Dual-Bay Rack for 3.5" Bay - RAID HDD Rack (HSB225S3R) - storage controller (RAID) - SATA 6Gb/s - SATA 6Gb/s
Storage controller (RAID) - internal
Bus Type
SATA 6Gb/s
Expansion Bays
2 x hot-swap - 2.5" SFF
Compatible Bay
1 3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
Hard drive, disk array (RAID), solid state drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Product Material
Plastic, aluminium
10.12 cm x 14 cm x 2.5 cm
220 g
Host Bus
SATA 6Gb/s
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
600 MBps
Supported Devices
2
RAID Level
ASMedia ASM1092R
Bays
2 x SATA 6Gb/s - SATA combo
1 x SATA 6Gb/s - 7 pin Serial ATA
Compatible Bay
1 x drive cage 3.5"
1 x Serial ATA cable - detachable , 1 x power 15 pin SATA to 4 pin adapter - detachable
TRIM support
10.12 cm
14 cm
2.5 cm
220 g
55 °C
5 - 65%
D72N StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £36.57
D72N StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £65.05
D72N StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £77.78
D72N StarTech.com Mobile Rack Backplane In Stock £23.34
D72N StarTech.com 4-Bay Backplane for SSD/HDD In Stock £67.80
D72N StarTech.com Hot Swap Bay 2.5" SATA SSD HDD In Stock £41.44
D72N StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £28.26
Price Range Ex VAT: 0 - 50
