Easily connect and hot swap two 2.5 in. SATA hard drives or SSDs through a single 3.5 in. front bay. This HDD rack lets you install two 2.5" SATA hard drives or solid-state drives into a single 3.5" front bay. With configurable RAID support, the SATA drive rack provides an ideal data storage solution.
Configure and arrange your drives for increased drive capacity, performance, or data redundancy, with built-in RAID functionality. With multiple RAID options, such as RAID 0, RAID 1, spanning, or JBOD, you can build the data storage solution that works best for you.
This SATA backplane is trayless and hot-swappable, which makes it easy to install and remove your drives from your computer system when required, without having to open the case every time. It also provides a more convenient way to create backups for data recovery and archiving.
The removable hard-drive bay/backplane features durable aluminum construction for long-lasting performance. The SATA backplane also has LED indicators for power and hard drive activity, and drive status, which makes it easy to monitor the status of your hard drives and RAID array.
- StarTech.com 2.5" SATA SSD / HDD Mobile Rack - Hot Swap Trayless Mobile Rack - Dual-Bay Rack for 3.5" Bay - RAID HDD Rack (HSB225S3R) - storage controller (RAID) - SATA 6Gb/s - SATA 6Gb/s
- Storage controller (RAID) - internal
- Bus Type
- SATA 6Gb/s
- Black
- Expansion Bays
- 2 x hot-swap - 2.5" SFF
- Compatible Bay
- 1 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, disk array (RAID), solid state drive
- Max Storage Devices Qty
- 2
- RAID Level
- RAID 0, RAID 1, JBOD, BIG
- Product Material
- Plastic, aluminium
- 10.12 cm x 14 cm x 2.5 cm
- 220 g
- 2-year warranty
- Host Bus
- SATA 6Gb/s
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 2
- RAID Level
- Processor
- ASMedia ASM1092R
- Bays
- 2 x SATA 6Gb/s - SATA combo
- Connections
- 1 x SATA 6Gb/s - 7 pin Serial ATA
- Compatible Bay
- 1 x drive cage 3.5"
- Cables Included
- 1 x Serial ATA cable - detachable , 1 x power 15 pin SATA to 4 pin adapter - detachable
- TRIM support
- Limited warranty - 2 years
- 10.12 cm
- 14 cm
- 2.5 cm
- 220 g
- 0 °C
- 55 °C
- 5 - 65%
StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F | In Stock | £4.49 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.89 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.76 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.45 |
StarTech.com 6in SATA to LP4 Power Cable Adapter - F/M | In Stock | £5.79 |
StarTech.com 6in Latching SATA Cable | In Stock | £2.61 |
StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F | In Stock | £5.10 |
StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £67.34 |
StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III | In Stock | £82.14 |
StarTech.com 4-Bay Backplane for SSD/HDD | In Stock | £79.56 |
StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £29.09 |
