StarTech.com 2.5in USB 3.0 SSD SATA Hard Drive Enclosure
Quicklinx: 7ZMPWS00 Mfr#: SAT2510BU32
  • Windows 8 (32/64 bits)
Turn a 2.5" SATA HDD/SSD into an external SuperSpeed USB 3.0 Hard Drive/Solid State Drive. The SAT2510BU32 2.5-inch SuperSpeed USB 3.0 SATA Hard Drive Enclosure turns a normal 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into a portable, external hard drive.
Connecting to a host computer through USB 3.0 with no external power required, this enclosure supports full SuperSpeed USB data transfer speeds up to 5 Gbps - 10x faster than the USB 2.0 standard, and is backward compatible with older USB connections (USB 2.0). Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Featuring a lightweight, portable design this USB 3.0 SATA HDD enclosure is constructed of aluminum, which offers maximum durability and operating heat dissipation.
StarTech.com 2.5in USB 3.0 SSD SATA Hard Drive Enclosure - Storage enclosure with power indicator - 2.5" - SATA 3Gb/s - 3 Gbit/s - USB 3.0 - black - SAT2510BU32 - storage enclosure - SATA 3Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
Power indicator
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
USB bus
Linux, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
7.5 cm x 12.3 cm x 1.25 cm
180 g
2.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Power indicator
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
1
ASMedia ASM1051
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA combo
1 x USB 3.0
USB (power) cable
Tested with up to 1TB 5400 RPM hard drives
Plug and Play, FCC, RoHS
Power Source
USB bus
7.5 cm
12.3 cm
1.25 cm
180 g
60 °C
10 - 90%
7ZMP StarTech.com Rugged Hard Drive Enclosure In Stock £33.99
7ZMP StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £27.64
