Turn a 7mm high 2.5in SATA III SSD/HDD into a UASP-supported USB 3.0 External Drive. This slim, pocket-sized drive enclosure is specifically engineered for 7mm drives, giving you the option to turn your thin hard drive or solid state drive into an external storage solution connected through UASP-enabled USB 3.0. With a thin yet durable design, the enclosure fits your 7mm drives perfectly to eliminate any drive movement inside the enclosure, which could be a problem with a looser-fitting enclosure.
To help save you time transferring data to and from your 7mm SSD or HDD, this UASP-enabled enclosure supports transfer speeds up to 70% faster than traditional USB 3.0, when used with a UASP-enabled host computer.
Plus, the enclosure is USB-powered, so you don't have to carry a power adapter with you, giving you one less thing to pack when you're traveling.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
Improved Performance with UASP
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
 - StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD / HDD - 7mm 2.5" Drive Enclosure - SATA 6 Gbps (S2510BPU337) - storage enclosure - SATA 6Gb/s - USB 3.0
 - Storage enclosure - external
- Bus Type
 - USB 3.0
 - Black
- Expansion Bays
 - 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
 - 2.5"
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 6 Gbit/s
- Supported Devices
 - Hard drive
- Max Storage Devices Qty
 - 1
- Product Material
 - Plastic
- Power Source
 - USB bus
- System Requirements
 - Linux, Apple MacOS X, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits)
 - 9.1 cm x 9.5 cm x 14.4 cm
 - 45 g
 - 2-year warranty
 - 2.5"
- Host Bus
 - USB 3.0
- Product Material
 - Plastic
 - Black
Storage Controller
- Interface
 - SATA 6Gb/s
 - 6 Gbit/s
- Supported Devices
 - Hard drive
 - 1
- Processor
 - ASMedia
- Bays
 - 1 x SATA 6Gb/s - SATA combo
- Connections
 - 1 x USB 3.0 - 9 pin Micro-USB Type B
- Cables Included
 - 1 x USB 3.0 cable - external
- Mounting Kit
 - Included
 - FCC, RoHS
- Power Source
 - USB bus
- OS Required
 - Limited warranty - 2 years
 - 9.1 cm
 - 9.5 cm
 - 14.4 cm
 - 45 g
 - 0 °C
 - 40 °C
 - 10 - 95%
                        StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
                        StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.08 |
                        StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £9.17 |
                        StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £7.36 |
                        StarTech.com Rugged Hard Drive Enclosure | In Stock | £32.20 |
                        StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £25.78 |
                        StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £48.05 |
