StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP
Quicklinx: 8XC6WS00 Mfr#: S2510BPU33
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
  • Windows 8 (32/64 bits)
£22.99 ex VAT
£27.58 inc VAT
Turn a 2.5" SATA Hard Drive or Solid State Drive into a UASP supported USB 3.0 External Hard Drive. The S2510BPU33 USB 3.0 Hard Drive Enclosure with UASP lets you connect a 2.5in SATA III hard drive (HDD) or solid state drive (SSD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 2.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 1TB) this HDD enclosure is compatible with virtually any 2.5in SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
For added portability the USB 3.0/SATA III enclosure features tool-less HDD installation, and requires no external power adapter.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Improved Performance with UASP
    UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP - Portable External USB HDD with Tool-less Installation (S2510BPU33) - storage enclosure - SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic
Power Source
USB bus
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
8.8 cm x 13.19 cm x 1.5 cm
70.1 g
P/N: HB30AM4AB, USB3VDOCKD, USBDUP15, USBDUPE115, USBDUPE17
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.0
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
5 GBps
Supported Devices
Hard drive
1
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 10 pin Micro-USB Type B
HDD pad
1 x USB cable - external - 45.7 cm
USB powered, LED indicator
RoHS
Power Source
USB bus
8.8 cm
13.19 cm
1.5 cm
70.1 g
10 - 90%
8XC6 StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £41.40
8XC6 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
8XC6 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £19.88
8XC6 StarTech.com Rugged Hard Drive Enclosure In Stock £32.49
8XC6 StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
8XC6 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.59
8XC6 StarTech.com M.2 SATA Enclosure with USB-C In Stock £25.86
8XC6 StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £27.05
8XC6 StarTech.com USB C to SATA Adapter Cable In Stock £34.82
8XC6 StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 In Stock £29.33
8XC6 StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA In Stock £49.25
HD Size: 2.5
Power Supply: [N/A]
