StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable
Quicklinx: 9651WS00 Mfr#: USB3S2SAT3CB
Type: Storage controller
HD Size: 2.5
Power Supply: [N/A]
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
More than 50 In Stock
£8.33 ex VAT
£9.99 inc VAT
Connect a 2.5in SATA hard drive to your computer using a portable cable with UASP Support. The USB3S2SAT3CB USB 3.0 to SATA adapter cable lets you connect a 2.5" SATA hard drive or solid state drive to your computer through an available USB port. The cable supports UASP, allowing for transfer speeds up to 70% faster than conventional USB 3.0, which enables you to utilize the full potential of your SATA III SSD/HDD, when paired with a UASP-enabled host controller.
his portable, cable-style adapter makes it easy to swap between hard drives without having to install your drives in an enclosure, and features a lightweight design with no external power required, for easy storage in a laptop bag or carrying case.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
  • Efficient data transfer
    Facilitates data transfer at speeds of up to 6 Gbit/s, ensuring rapid access to files and backups.
  • Extensive device compatibility
    Supports both SATA hard drives and solid state drives, providing a flexible storage solution.
  • User-friendly design
    External form factor allows for easy connection without the need for additional power sources.
  • Robust environmental resilience
    Functions efficiently within a broad range of temperatures and humidity levels, making it reliable in various conditions.
  • Widespread system support
    Compatible with both Mac and Windows systems, suitable for diverse computing environments.
StarTech.com SATA to USB Cable - USB 3.0 to 2.5" SATA III Hard Drive Adapter - External Converter for SSD/HDD Data Transfer (USB3S2SAT3CB) - storage controller - SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
4.5 cm x 50 cm x 1 cm
189 g
2.5"
Host Bus
USB 3.0
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASMedia ASM1051E
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external
FCC, RoHS
4.5 cm
50 cm
1 cm
189 g
60 °C
40 - 85%
9651 StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £21.26
9651 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.48
9651 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
9651 StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £23.61
9651 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £17.59
9651 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
9651 StarTech.com CFast Card Reader - USB 3.0 In Stock £22.38
9651 StarTech.com CFast Card Reader - USB-C In Stock £28.39
9651 StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £24.82
9651 StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £80.54
HD Size: 2.5
Power Supply: [N/A]
