Turn a 2.5" SATA Hard Drive or Solid State Drive into a UASP supported USB 3.0 External Hard Drive. The S2510BPU33 USB 3.0 Hard Drive Enclosure with UASP lets you connect a 2.5in SATA III hard drive (HDD) or solid state drive (SSD) through an available USB port. The enclosure delivers optimal performance with a USB 3.0 connection, but is backward compatible with USB 2.0/1.1 host connections as well.
Enhanced with UASP (USB Attached SCSI Protocol), this 2.5" SATA III enclosure performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller. Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP reduces latency, significantly increasing transfer speeds and reducing processor usage to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, and large capacity drives (tested up to 1TB) this HDD enclosure is compatible with virtually any 2.5in SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
For added portability the USB 3.0/SATA III enclosure features tool-less HDD installation, and requires no external power adapter.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
Improved Performance with UASP
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance. At the same peak in testing UASP also shows an 80% reduction in required processor resources. Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com Enclosure, and a SATA III solid state drive.
- StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP - Portable External USB HDD with Tool-less Installation (S2510BPU33) - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 5 GBps
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic
- Power Source
- USB bus
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 8.8 cm x 13.19 cm x 1.5 cm
- 70.1 g
- 2-year warranty
- Designed For
- P/N: HB30AM4AB, USB3VDOCKD, USBDUP15, USBDUPE115, USBDUPE17
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.0
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 5 GBps
- Supported Devices
- Hard drive
- 1
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Included Accessories
- HDD pad
- Cables Included
- 1 x USB cable - external - 45.7 cm
- USB powered, LED indicator
- RoHS
- Power Source
- USB bus
- OS Required
- Limited warranty - 2 years
- 8.8 cm
- 13.19 cm
- 1.5 cm
- 70.1 g
- 10 - 90%
- Designed For
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £27.08 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.11 |
StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP | In Stock | £19.39 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £32.20 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £26.19 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £16.51 |
StarTech.com M.2 SATA Enclosure with USB-C | In Stock | £25.64 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £26.81 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.51 |
StarTech.com M.2 SSD Enclosure for M.2 SATA Drives - USB 3.1 - USB C M.2 | In Stock | £29.06 |
StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £48.05 |
