This SATA or USB to Dual Compact Flash Solid State Drive adapter features a SATA male power connector and a SATA male data connector, a Mini USB B connector, as well as two Compact Flash ports, allowing you to connect two Compact Flash type media cards to a laptop computer in place of a Serial ATA (SATA) hard drive. The USB 2.0 interface allows it to be connected directly to a Desktop or Notebook PC. The USB connection provides both data and power to the adapter allowing the CF cards to be accessed without requiring any additional adapters or cables. The adapter also features three RAID modes for card configuration; RAID 0 (Stripping), RAID 1(Mirroring), and BIG (Concatenation). A Do-it-yourself SSD solution, the SATA to CF adapter allows Compact Flash, Compact Flash 2, or MicroDrive media to be used on a notebook computer as a bootable hard drive and requires no software or driver installation.
- StarTech.com 2.5in SATA or USB to Dual Compact Flash SSD Adapter with RAID - storage controller (RAID) - CompactFlash - SATA 3Gb/s, USB 2.0
- Storage controller (RAID)
- Bus Type
- Compatible Bay
- 1 2.5"
- Interface
- CompactFlash
- Data Transfer Rate
- 3 GBps
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1
- Supported Flash Memory
- CompactFlash Card type I, CompactFlash Card type II, CompactFlash Card
- System Requirements
- Microsoft Windows Server 2003, Apple MacOS X 10.4.x, Microsoft Windows Vista / XP, Red Hat Fedora Core 6, Apple MacOS X 10.5.x
- 6.9 cm x 8.3 cm x 0.9 cm
- 60 g
- 1-year warranty
- Host Bus
Storage Controller
- Interface
- CompactFlash
- 3 GBps
- Supported Devices
- Disk array (RAID)
- RAID Level
- RAID 0, RAID 1
- 2 x CompactFlash
- Connections
- 1 storage - Serial ATA-300 - 22 pin Serial ATA , 1 x USB 2.0 - mini-USB Type B
- Compatible Bay
- 1 x internal 2.5"
- Cables Included
- 1 x USB cable - external
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 1 year
- 6.9 cm
- 8.3 cm
- 0.9 cm
- 60 g
- 5 °C
- 50 °C
- 20 - 80%
