StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure
Quicklinx: 7WZ7WS00 Mfr#: SAT2MSAT25
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
Hurry, only 3 left in stock!
£29.96 ex VAT
£35.95 inc VAT
The SAT2MSAT25 2.5in SATA to Mini SATA SSD Adapter Enclosure turns an mSATA (Mini SATA) mini-SSD into a standard 2.5in SATA SSD for use anywhere a 2.5in SATA drive can be used. Featuring all of the standard mounting points that a normal 2.5in hard drive uses, the converter can be installed into External Hard Drive Enclosures, Hard Drive Docking Stations or into desktop or laptop computers. The enclosure also features a unique design that enables seamless data pass-through with no conversion bottlenecks, enabling the mSATA drive to work as fast as it's allowed by the host system/interface.
StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure - Mini PCIe ssd Adapter - SATA to mSATA - Mini PCIe SATA (SAT2MSAT25) - storage enclosure - SATA
Storage enclosure - external
Bus Type
SATA
Silver
Hard Drive Form Factor Compatibility
2.5"
Supported Devices
Hard drive
Channel Qty
1
Product Material
Plastic, aluminium
Microsoft Windows 7, Microsoft Windows Vista
6.8 cm x 9.8 cm x 1 cm
50 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SU2DUPERA11
2.5"
Host Bus
SATA
Product Material
Plastic, aluminium
Silver
Storage Controller
Supported Devices
Hard drive
Channel Qty
1
No CPU
1 x SATA 3Gb/s - SATA
1 storage - Serial ATA-300 - 52 pin mini-SATA
RoHS
6.8 cm
9.8 cm
1 cm
50 g
50 °C
50 - 95%
7WZ7 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
7WZ7 StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
7WZ7 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
7WZ7 StarTech.com 12in Latching SATA Cable In Stock £6.16
7WZ7 StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
7WZ7 StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
7WZ7 StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
7WZ7 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
7WZ7 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
7WZ7 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
7WZ7 StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
7WZ7 StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
7WZ7 StarTech.com M.2 to U.2 Adapter In Stock £23.11
7WZ7 StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £132.24
HD Size: 2.5
Power Supply: [N/A]
