StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit
Quicklinx: 5D2XWS00 Mfr#: BRACKET25SAT
17 in stock
£6.90 ex VAT
£8.28 inc VAT
Mount a 2.5in SATA hard drive to any desktop with an available 3.5in bay. This Serial ATA hard drive mounting kit allows you to install a 2.5in SATA hard drive in a 3.5in drive bay. The 2.5in to 3.5in SATA hard drive mounting kit features a sturdy aluminum bracket, as well as a combined 7+15 pin SATA + LP4 Power to SATA cable - which helps simplify installation and reduce clutter within the computer case.
StarTech.com SSD Mounting Bracket - Solid Metal - 2.5in to 3.5 Hard Drive Adapter - SSD Bracket - SSD Upgrade Kit (BRACKET25SAT) - storage bay adapter
Storage bay adapter
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Aluminium
9.8 cm x 10 cm x 1 cm
110 g
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
Storage bay adapter
Product Material
Aluminium
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
1 x Serial ATA cable - internal
RoHS
9.8 cm
10 cm
1 cm
110 g
5D2X StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £3.14
5D2X StarTech.com 18in SATA Serial ATA Cable In Stock £3.68
5D2X StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £1.80
5D2X StarTech.com 36in SATA Serial ATA Cable In Stock £3.45
5D2X StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.24
5D2X StarTech.com SATA to LP4 Power Cable Adapter In Stock £4.62
5D2X StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit In Stock £6.90
Stock Status: In stock
