Mount a 2.5in SATA hard drive to any desktop with an available 3.5in bay. This Serial ATA hard drive mounting kit allows you to install a 2.5in SATA hard drive in a 3.5in drive bay. The 2.5in to 3.5in SATA hard drive mounting kit features a sturdy aluminum bracket, as well as a combined 7+15 pin SATA + LP4 Power to SATA cable - which helps simplify installation and reduce clutter within the computer case.
- StarTech.com SSD Mounting Bracket - Solid Metal - 2.5in to 3.5 Hard Drive Adapter - SSD Bracket - SSD Upgrade Kit (BRACKET25SAT) - storage bay adapter
- Storage bay adapter
- Expansion Bays
- 1 x internal - 2.5"
- Compatible Bay
- 1 3.5"
- Product Material
- Aluminium
- 9.8 cm x 10 cm x 1 cm
- 110 g
- 2-year warranty
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
- Product Material
- Aluminium
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x internal 3.5"
- Cables Included
- 1 x Serial ATA cable - internal
- RoHS
- Limited warranty - 2 years
- 9.8 cm
- 10 cm
- 1 cm
- 110 g
- Designed For
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £4.58 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.42 |
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £3.01 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.68 |
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.44 |
StarTech.com SATA to LP4 Power Cable Adapter | In Stock | £5.23 |
StarTech.com 2.5in SATA Removable Hard Drive Bay for PC Expansion Slot | In Stock | £26.17 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £13.89 |
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.33 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £19.99 |
StarTech.com 2.5" SSD/HDD Mounting Bracket | In Stock | £4.34 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £23.71 |
StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay | In Stock | £16.62 |
