StarTech.com 2.5 to 3.5 Hard Drive Adapter
Quicklinx: F2HDWS00 Mfr#: 25SATSAS35HD
Type: Adapter
£22.60 ex VAT
£27.12 inc VAT
Turn almost any 2.5" SATA/SAS drive into a 3.5" drive. This 2.5" to 3.5" hard drive adapter lets you install a 2.5" SATA or SAS hard drive (HDD) or solid-state drive (SSD) into an internal or external 3.5" drive bay, using standard drive-mounting holes.
The 2.5" to 3.5" hard drive bay adapter lets you install a newer, higher performance drive such as an SSD into a legacy system that may only support a 3.5" hard drive. It provides a cost-efficient way to enhance storage performance and reliability without expensive upgrades to core IT systems. It's also ideal for system administrators who want to build a system that takes advantage of the increased performance of a 2.5" HDD/SSD.
To utilize the full speed potential of your SATA/SAS drive, the adapter supports transfer speeds up to 6Gbps.
You can install the adapter into a desktop, server, storage-array, hot-swap bay, and drive drawer. It offers permanent installation in a 3.5" drive bay with standard mounting holes. When the adapter is installed, you simply slide a 2.5" HDD/SSD into the adapter enclosure, with no tools required.
The adapter is suitable for drives with a height of up to 15 mm. Virtually any 2.5" SATA/SAS drive can be made to look and function like a 3.5" drive.
The adapter includes a label you can use to track and record information about the installed drive.
  • Versatile compatibility
    Designed to accommodate both 2.5-inch and 3.5-inch drives, the StarTech.com adapter offers flexibility for different storage types, making it a valuable addition to any setup.
  • High-speed data transfer
    With data transfer rates reaching up to 6 Gbit/s, this adapter ensures quick access to data, enhancing overall system performance and efficiency.
  • Hot-swappable design
    This feature allows for easy insertion and removal of drives without needing to power down the system, facilitating seamless upgrades and maintenance.
  • Robust construction
    Made from both plastic and aluminum, the enclosure is designed for durability, providing reliable protection for your valuable data storage.
  • Compliant with industry standards
    Meets FCC, RoHS, and WEEE standards, ensuring the product aligns with environmental and safety regulations, thus fostering responsible usage.
StarTech.com 2.5 to 3.5 Hard Drive Adapter - For SATA and SAS SSDs/HDDs - SSD Enclosure - HDD Enclosure - Internal Hard Drive Enclosure (25SATSAS35HD) - storage enclosure - SATA 6Gb/s / SAS 6Gb/s - SAS 6Gb/s, SATA 6Gb/s
Storage enclosure - internal
Bus Type
Black, silver
Expansion Bays
1 x internal - 2.5" x 1/8H
Compatible Bay
1 3.5" x 1/3H
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600 / SAS 2.0
Drive Connector
29 pin internal SAS (SFF-8482)
Bay Connector
22 pin Serial ATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic, aluminium
10.1 cm x 14.6 cm x 2.6 cm
252 g
2.5"
Hard Drive Maximum Height
15 mm
Host Bus
Product Material
Plastic, aluminium
Black, silver
Supported Interface
SATA-600 / SAS 2.0
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Bays
1 x SATA 6Gb/s
1 - 22 pin Serial ATA
Compatible Bay
1 x internal 3.5" x 1/3H
Hot-swappable, S.M.A.R.T. support, TRIM support, 4Kn drive compatible
Mounting Kit
Included
FCC, RoHS, WEEE
10.1 cm
14.6 cm
2.6 cm
252 g
Shipping Weight
252 g
55 °C
5 - 65%
F2HD StarTech.com 24" Serial ATA Cable In Stock £5.16
F2HD StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £2.95
F2HD StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
F2HD StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.79
F2HD StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.31
F2HD StarTech.com 6in SATA Serial ATA Cable In Stock £3.57
F2HD StarTech.com 12in SATA Serial ATA Cable In Stock £4.88
F2HD StarTech.com 6in Latching SATA Cable In Stock £2.60
F2HD StarTech.com 5.25 to 3.5 Drive Hot Swap Bay In Stock £29.09
Type: Adapter
