Turn almost any 2.5" SATA/SAS drive into a 3.5" drive. This 2.5" to 3.5" hard drive adapter lets you install a 2.5" SATA or SAS hard drive (HDD) or solid-state drive (SSD) into an internal or external 3.5" drive bay, using standard drive-mounting holes.
The 2.5" to 3.5" hard drive bay adapter lets you install a newer, higher performance drive such as an SSD into a legacy system that may only support a 3.5" hard drive. It provides a cost-efficient way to enhance storage performance and reliability without expensive upgrades to core IT systems. It's also ideal for system administrators who want to build a system that takes advantage of the increased performance of a 2.5" HDD/SSD.
To utilize the full speed potential of your SATA/SAS drive, the adapter supports transfer speeds up to 6Gbps.
You can install the adapter into a desktop, server, storage-array, hot-swap bay, and drive drawer. It offers permanent installation in a 3.5" drive bay with standard mounting holes. When the adapter is installed, you simply slide a 2.5" HDD/SSD into the adapter enclosure, with no tools required.
The adapter is suitable for drives with a height of up to 15 mm. Virtually any 2.5" SATA/SAS drive can be made to look and function like a 3.5" drive.
The adapter includes a label you can use to track and record information about the installed drive.
                Versatile compatibilityDesigned to accommodate both 2.5-inch and 3.5-inch drives, the StarTech.com adapter offers flexibility for different storage types, making it a valuable addition to any setup.
                High-speed data transferWith data transfer rates reaching up to 6 Gbit/s, this adapter ensures quick access to data, enhancing overall system performance and efficiency.
                Hot-swappable designThis feature allows for easy insertion and removal of drives without needing to power down the system, facilitating seamless upgrades and maintenance.
                Robust constructionMade from both plastic and aluminum, the enclosure is designed for durability, providing reliable protection for your valuable data storage.
                Compliant with industry standardsMeets FCC, RoHS, and WEEE standards, ensuring the product aligns with environmental and safety regulations, thus fostering responsible usage.
- StarTech.com 2.5 to 3.5 Hard Drive Adapter - For SATA and SAS SSDs/HDDs - SSD Enclosure - HDD Enclosure - Internal Hard Drive Enclosure (25SATSAS35HD) - storage enclosure - SATA 6Gb/s / SAS 6Gb/s - SAS 6Gb/s, SATA 6Gb/s
- Storage enclosure - internal
- Bus Type
- Black, silver
- Expansion Bays
- 1 x internal - 2.5" x 1/8H
- Compatible Bay
- 1 3.5" x 1/3H
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600 / SAS 2.0
- Drive Connector
- 29 pin internal SAS (SFF-8482)
- Bay Connector
- 22 pin Serial ATA
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic, aluminium
- 10.1 cm x 14.6 cm x 2.6 cm
- 252 g
- 2-year warranty
- 2.5"
- Hard Drive Maximum Height
- 15 mm
- Host Bus
- Product Material
- Black, silver
Storage Controller
- Interface
- 6 Gbit/s
- Supported Devices
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 - 22 pin Serial ATA
- Compatible Bay
- 1 x internal 3.5" x 1/3H
- Hot-swappable, S.M.A.R.T. support, TRIM support, 4Kn drive compatible
- Mounting Kit
- Included
- FCC, RoHS, WEEE
- Limited warranty - 2 years
- 10.1 cm
- 14.6 cm
- 2.6 cm
- 252 g
- Shipping Weight
- 252 g
- 0 °C
- 55 °C
- 5 - 65%
|  | StarTech.com 24" Serial ATA Cable | In Stock | £5.16 |
|  | StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £2.95 |
|  | StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
|  | StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.45 |
|  | StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive | In Stock | £17.68 |
|  | StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.55 |
|  | StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.44 |
|  | StarTech.com 6in Latching SATA Cable | In Stock | £2.61 |
|  | StarTech.com 5.25 to 3.5 Drive Hot Swap Bay | In Stock | £29.09 |
