StarTech.com 2.5 ft Retractable USB Combo Cable – USB to Micro USB and Mini USB – M/M
Quicklinx: 95XNWS00 Mfr#: USBRETAUBMB
Charge or sync your Micro or Mini USB mobile devices anywhere you go with this portable USB 2.0 combo cable. The USBRETAUBMB 2.5ft Retractable USB to Micro and Mini USB Combo Cable lets you connect a variety of mobile devices, such as smartphones, tablet PCs, or digital cameras, to your computer for everyday tasks such as charging, data synchronization or file transfers.
This 2-in-1 multifunction cable is the perfect solution for connecting your Mini USB or Micro USB device while avoiding the hassle of swapping in and out between 2 separate cables.
Plus, the retractable, compact and lightweight design provides a portable solution that makes it perfect for carrying as an accessory in your laptop bag or carrying case.
StarTech.com 2.5 ft Retractable USB Combo Cable - USB to Micro USB and Mini USB M/M - 2 in 1 USB to Mini & Micro USB - Data & Charge Cable (USBRETAUBMB) - USB cable - 76.2 cm
USB cable
Retractable
Length
76.2 cm
Connectors
4 pin USB Type A - male
Connectors (Second End)
Mini-USB Type B - male , 5 pin Micro-USB Type B - male
P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
USB cable
Plated Connector
Nickel
Retractable
Length
76.2 cm
Connectors
RoHS
