StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm
Quicklinx: 9657WS00 Mfr#: 25SAT35HDD
Type: Adapter
19 In Stock
£19.99 ex VAT
£23.98 inc VAT
Turn a 2.5" SATA HDD/SSD into a 3.5" SATA Drive. The 25SAT35HDD 2.5" to 3.5" hard drive adapter enclosure turns a 2.5" SATA hard drive (HDD) or solid state drive (SSD) into a 3.5" drive.
The adapter enclosure lets you substitute a 3.5" hard drive for a 2.5" SSD/HDD in any application that would typically require a 3.5" drive, such as desktop chassis, backplane, or docking station. The enclosure has the same dimensions as a standard 3.5" hard drive, including mounting points, and SATA connector locations.
With support for drives up to 12.5mm in height, and high-capacity SATA I/II/III drives (tested up to 1TB) this HDD adapter ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
  • Seamless compatibility
    Designed to bridge the gap between 2.5" and 3.5" drive sizes, the StarTech.com SATA HDD/SSD Adapter Enclosure ensures seamless compatibility with both PC and Mac systems. This flexibility makes it an ideal solution for diverse computing environments.
  • High-speed performance
    With support for SATA 6Gb/s interface, this external hard drive converter facilitates data transfer rates up to 6 Gbit/s, enabling swift and efficient file transfers and backups.
  • Durable construction
    Crafted from a combination of aluminum and plastic, the enclosure is built for durability. Its robust construction not only protects your hard drive but also ensures longevity of the device.
  • Optimized for enhanced reliability
    The adapter enclosure is tested with up to 1TB 7200 RPM 2.5" hard drives, demonstrating its capability to handle high-performance drives reliably for extended periods.
StarTech.com 2.5" to 3.5" SATA HDD/SSD Adapter Enclosure - External Hard Drive Converter with HDD/SSD Height up to 12.5mm (25SAT35HDD) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s
Storage enclosure - internal
Bus Type
SATA 6Gb/s
Expansion Bays
1 x internal - 2.5" x 1/8H
Compatible Bay
1 3.5" x 1/3H
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600
Drive Connector
22 pin Serial ATA
Bay Connector
22 pin Serial ATA
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic, aluminium
10.2 cm x 14.6 cm x 3.6 cm
260 g
P/N: S352BU33HR
2.5"
Host Bus
SATA 6Gb/s
Product Material
Plastic, aluminium
Supported Interface
SATA-600
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Bays
1 x SATA 6Gb/s
1 - 22 pin Serial ATA
Compatible Bay
1 x internal 3.5" x 1/3H
1 x Serial ATA cable
Tested with up to 1TB 7200 RPM 2.5" hard drives
FCC, RoHS
10.2 cm
14.6 cm
3.6 cm
260 g
Shipping Width
11.5 cm
Shipping Depth
16.3 cm
Shipping Height
3.8 cm
Shipping Weight
260 g
5 °C
55 °C
5 - 85%
P/N: S352BU33HR
9657 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.42
9657 StarTech.com 18in SATA Serial ATA Cable In Stock £2.51
9657 StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
9657 StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.45
9657 StarTech.com SATA to LP4 Power Cable Adapter In Stock £3.80
9657 StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.71
9657 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.16
9657 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.12
9657 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £19.99
9657 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £67.34
9657 StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £22.96
Type: Adapter
