StarTech.com 1U Rackmount 4-Bay 3.5" SATA / SAS External Hard Drive Enclosure w/ SATA 6 Gbps
Quicklinx: 92PXWS00 Mfr#: SAT35401U
Turn four 3.5" SATA/SAS drives into a 1U rack-mountable storage solution with external Mini SAS connectivity. The SAT35401U Rack-mountable 4-bay trayless HDD enclosure enables you to mount and hot-swap up to four 3.5" SATA or SAS hard drives into 1U of rack/cabinet storage space.
To ensure maximum performance and versatility, the enclosure offers support for SATA/SAS HDD speeds up to 6.0 Gbps with a mini SAS interface and is fully compatible with RAID controllers for enhanced storage applications.
The rugged steel rack-mountable chassis with 3 built-in fans makes it an ideal solution for any server environment that requires hot-swappable storage.
StarTech.com 1U Rackmount 4-Bay 3.5" SATA/SAS External Hard Drive Enclosure - hard drive array
Hard drive array
SAS 6Gb/s
4 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
SATA/SAS-2 (SATA 6Gb/s / SAS 6Gb/s)
Hard Drive
0 HDD - hot-swap
Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
AC 120/230 V
30.2 cm x 44 cm x 5.35 cm
5.8 kg
P/N: SVA12DN4NEUA
Hard drive array
Enclosure Colour
Chassis
Supported Devices / Modules Qty
4
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
SAS 6Gb/s
Storage Controller
SATA/SAS-2
Channel Qty
4
Interface Type
Data Transfer Rate
600 MBps
Hard Drive
HDD - hot-swap
0
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5"
1 x SAS 6Gb/s
Built-in 3 cooling fans
Mounting Kit
Included
WHQL, FCC, RoHS
External power adapter
AC 120/230 V
30.2 cm
44 cm
5.35 cm
5.8 kg
5 °C
35 °C
20 - 80%
P/N: SVA12DN4NEUA
92PX StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £44.84
92PX StarTech.com 1m External Mini SAS Cable - Serial Attached SCSI SFF-8088 to SFF-8088 In Stock £57.13
92PX StarTech.com 2m External Mini SAS Cable - Serial Attached SCSI SFF-8088 to SFF-8088 In Stock £27.11
92PX StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
92PX StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
