Mount 19" servers or networking hardware in any standard rack. The UNIRAILS1U 1U Fixed 19-inch Adjustable Depth Universal Server Rack Rails enable you to fit non-rack mountable equipment (weight up to 25kg/55lbs) into a standard 19-inch rack.
Featuring sturdy, cold-rolled steel construction, adjustable depth configurations for varying rack sizes, horizontal equipment supports, and multiple mounting hole patterns to secure your equipment, this durable 19" rack rails kit makes mounting your non-rackmount equipment quick and easy!
- StarTech.com 1U Universal Server Rack Rails - TAA Compliant Adjustable Depth Server Mounting Rails - 19inch Rack Mount Rails (UNIRAILS1U) - rack rail - 1U
- Product Type
- Rack rail
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Steel
- 46.5 cm x 48.1 cm x 4.4 cm
- 2.6 kg
- Adjustable depth
- Limited lifetime warranty
- Designed For
- P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Rack rail
- Product Material
- Steel
- Rack Size
- 19"
- 1U
- 46.5 cm
- 48.1 cm
- 4.4 cm
- 2.6 kg
- Black
- Weight Limit
- 25 kg
- Mounting Kit
- Included
- Adjustable depth
- UL, RoHS
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
