StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails
Quicklinx: 7X1DWS00 Mfr#: UNIRAILS2U
Product Type: Rack rail
£72.65 ex VAT
£87.18 inc VAT
Mount 19" servers or networking hardware in any standard rack with these universal, adjustable depth 2U rack rails. The UNIRAILS2U 2U Fixed 19-inch Server Rack Rails (Adjustable Depth, Universal) enables you to fit non-rack mountable equipment at weight capacities up to 45kg (100lbs.) into standard 19-inch racks. Featuring sturdy, cold-rolled steel construction, adjustable depth configurations for varying rack sizes, horizontal equipment supports, and multiple mounting hole patterns to secure your equipment, this universal rack rail kit makes mounting your non-rackmount equipment quick and easy.
  • Turn non-rackmount equipment into 2U rackmount hardware
    These rack rails add rackmount functionality to your non-rackmount gear, by cradling your equipment in an open frame supported by three sturdy crossbars. You can mount your non-rackmount equipment by mounting the rails to your server rack and placing your equipment on the undercarriage. For equipment that already features mounting holes, the rails also feature multiple mounting patterns to secure your equipment, for an added level of security.
  • Universal design mounts to almost any 19" server rack
    Adhering to the EIA-310 standard for 19" rackmount equipment, these mounting rails are universally compatible with 19" server racks. The depth is adjustable for a variety of rack sizes and configurations. Plus, there is a rear cable management panel that's removable for additional customization.
  • Maximum durability
    To ensure your equipment is secure, these mounting rails feature cold-rolled steel construction. The durable design can support a weight load of up to 100 lb (45 kg). The UNIRAILS2U is backed by a lifetime StarTech.com warranty with free technical support.
StarTech.com 2U Universal Rack Mount Rails - for 19in Server Rack Enclosure or Cabinet - Adjustable A/V Rack Rails (UNIRAILS2U) - rack rail - 2U
Rack rail
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
46.5 cm x 48.1 cm x 8.8 cm
3.7 kg
Adjustable depth
P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack rail
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
46.5 cm
48.1 cm
8.8 cm
3.7 kg
Weight Limit
45 kg
Mounting Kit
Included
Adjustable depth
UL, RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
7X1D StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
7X1D StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7X1D StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7X1D StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £93.48
7X1D StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
7X1D StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
7X1D StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
