StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails
Quicklinx: 7X1CWS00 Mfr#: UNIRAILS1U
Product Type: Rack rail
21 in stock
£57.99 ex VAT
£69.58 inc VAT
Mount 19" servers or networking hardware in any standard rack. The UNIRAILS1U 1U Fixed 19-inch Adjustable Depth Universal Server Rack Rails enable you to fit non-rack mountable equipment (weight up to 25kg/55lbs) into a standard 19-inch rack.
Featuring sturdy, cold-rolled steel construction, adjustable depth configurations for varying rack sizes, horizontal equipment supports, and multiple mounting hole patterns to secure your equipment, this durable 19" rack rails kit makes mounting your non-rackmount equipment quick and easy!
StarTech.com 1U Universal Server Rack Rails - TAA Compliant Adjustable Depth Server Mounting Rails - 19inch Rack Mount Rails (UNIRAILS1U) rack rail - 1U
Rack rail
Rack Size
19"
Height (Rack Units)
1U
Product Material
Steel
46.5 cm x 48.1 cm x 4.4 cm
2.6 kg
Adjustable depth
P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack rail
Product Material
Steel
Rack Size
19"
Height (Rack Units)
1U
46.5 cm
48.1 cm
4.4 cm
2.6 kg
Weight Limit
25 kg
Mounting Kit
Included
Adjustable depth
UL, RoHS
Limited warranty - lifetime
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Stock Status: In stock
