StarTech.com 1m USB-C to DVI Cable
Quicklinx: CHN0WS00 Mfr#: CDP2DVIMM1MB
£22.25 ex VAT
£26.70 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to a DVI display, without additional adapters. This USB-C to DVI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DVI-I monitor, television or projector.
The adapter supports a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. For longer installations, a 2 m (6 ft.) USB-C to DVI cable enable you to choose the right cable length for your custom installation needs.
The USB-C to DVI adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 2560x1600, providing full dual-link support for your high-resolution DVI monitors - great for multitasking on high-resolution DVI displays. The adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other HD work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Clutter-free installation
    At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your DVI monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation.
  • Hassle-free connection with USB Type-C
  • Crystal-clear picture quality
StarTech.com 3.3 ft / 1 m USB-C to DVI Cable - USB Type-C Video Adapter Cable - 1920 x 1200 - Black (CDP2DVIMM1MB) - USB / DVI cable - 24 pin USB-C to DVI-D - 1 m
USB / DVI cable
1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
Length
1 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
24+1 pin digital DVI - male (output)
Thunderbolt 3 / USB 3.1
3-year warranty
P/N: TB4CDOCK
USB / DVI cable
Length
1 m
93 g
Connector
Thunderbolt 3 / USB 3.1, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
2.3 cm
Shipping Weight
107 g
3-year warranty
P/N: TB4CDOCK
CHN0 StarTech.com USB-C to VGA Adapter In Stock £24.56
CHN0 StarTech.com USB-C to VGA Adapter - White In Stock £22.46
CHN0 StarTech.com USB-C to HDMI Adapter In Stock £19.31
CHN0 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £31.23
CHN0 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £23.07
CHN0 StarTech.com 2m USB-C to DVI Cable In Stock £24.22
CHN0 StarTech.com 2m USB-C to HDMI Cable In Stock £28.73
CHN0 StarTech.com USB-C to VGA - Power Delivery In Stock £10.58
CHN0 StarTech.com 1m USB-C to DVI Cable In Stock £22.25
CHN0 StarTech.com 1m USB-C to HDMI Cable In Stock £25.98
CHN0 StarTech.com 1m USB-C to VGA Cable In Stock £19.52
CHN0 StarTech.com 2m USB-C to VGA Cable In Stock £21.01
CHN0 StarTech.com USB-C to HDMI - Power Delivery In Stock £24.47
CHN0 StarTech.com 2m USB C to HDMI Cable - Black In Stock £28.14
CHN0 StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.98
CHN0 StarTech.com 3m USB C to HDMI Cable - Black In Stock £29.24
CHN0 StarTech.com 1m USB C to HDMI Cable - White In Stock £24.73
CHN0 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
CHN0 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.98
CHN0 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.97
CHN0 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £22.34
CHN0 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.79
CHN0 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £17.06
CHN0 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £31.40
