StarTech.com 1m USB C to HDMI Cable - White
Quicklinx: D9T0WS00 Mfr#: CDP2HD1MWNL
Length: 1m
Select:
  • 1m
21 In Stock
£24.31 ex VAT
£29.17 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television, or projector. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
Clutter-free installation
While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports HDMI. At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation.
For longer installations, StarTech.com also offers a 2 m (6 ft.) USB-C to HDMI cable (CDP2HD2MWNL) and a 3 m (10 ft.) USB-C to HDMI cable (CDP2HD3MWNL), enabling you to choose the right cable length for your custom installation needs.
Astonishing picture quality
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
The CDP2HD1MWNL is backed by a 3-year StarTech.com warranty and free lifetime technical support.
  • Clutter-free installation
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60 Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60 Hz implementation.
StarTech.com 3ft (1m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, White - 4K USB-C Video Cable (CDP2HD1MWNL) - adapter cable - HDMI / USB - 1 m
Cable
Adapter cable - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Length
1 m
White
Connector
24 pin USB-C - male (input)
Connector (Second End)
HDMI - male (output)
Displayport 1.2/Thunderbolt 3
4K60Hz (3840 x 2160) support
3-year warranty
P/N: TB4CDOCK
Cable Type
Adapter cable 4K60Hz (3840 x 2160) support
Interface Supported
HDMI / USB
Length
1 m
HBR2 audio support, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
White
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Apple MacOS, Linux, Android, Google Chrome OS, Windows 10, Apple iPadOS
Connector
19 pin HDMI Type A - male (output)
FCC, RoHS, HDCP 2.2, HDCP 1.4
50 g
Shipping Width
2 cm
Shipping Depth
110 cm
Shipping Height
1 cm
Shipping Weight
50 g
Limited warranty - 3 years
P/N: TB4CDOCK
D9T0 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
D9T0 StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
D9T0 StarTech.com 2m USB C to HDMI Cable - Black In Stock £27.71
D9T0 StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.65
D9T0 StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.99
D9T0 StarTech.com 1m USB C to HDMI Cable - White In Stock £24.31
D9T0 StarTech.com 3m USB-C to DVI Cable - Black In Stock £25.34
D9T0 StarTech.com 3m USB C to VGA Cable - Black In Stock £30.07
Length: 1m
