StarTech.com 1m USB A to C Cable - USB 3.0
Quicklinx: CY2VWS00 Mfr#: USB315AC1M
Length: 1m
More than 50 In Stock
£8.23 ex VAT
£9.87 inc VAT
Connect your USB Type-C devices to your computer. This USB to USB-C cable lets you connect your USB 3.0, USB Type-C devices such as a hard drive, or mobile device to the USB Type-A port on your computer, charger or tablet.
  • Efficient data transfer
    With a data rate of 5 Gbps, this cable enables quick and efficient synchronization between devices, ensuring that large files are transferred without delay.
  • Durable construction
    The cable features a robust PVC jacket and nickel-plated connectors, which provide protection against wear and tear, making it a lasting solution for daily use.
  • Broad compatibility
    Equipped with both USB Type-A and USB-C connectors, this cable allows seamless connections with a variety of devices, enhancing its utility across different applications.
  • Compliant standards
    This cable adheres to USB 3.0 standards and is RoHS and WEEE compliant, ensuring safety and environmental responsibility without sacrificing performance.
StarTech.com USB to USB C Cable - 1m / 3 ft - 5Gbps - USB A to USB C - USB Type C - USB Cable Male to Male - USB C to USB (USB315AC1M) - USB cable - USB to 24 pin USB-C - 1 m
USB cable
Sync and charge, 5 Gbps data rate
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB 3.0
P/N: HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, HBS304A24A, MST30C2HDPPD
USB cable
Jacket Material
PVC
American Wire Gauge (AWG)
24/32
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB 3.0, RoHS, WEEE
Length: 1m
