The StarTech.com 4-Port USB-A PCIe Card is a versatile addition to any desktop, enhancing your PC with additional USB 3.2 Gen 1 ports. This card allows for the connection of multiple devices simultaneously, including external hard drives, HD cameras, and more, with a high-speed data transfer rate of 5 Gbps. It supports USB Power Delivery of up to 10 W, ensuring that connected devices are efficiently charged. Designed for easy installation, the card fits into PCI Express 2.0 x4 slots and includes internal power connectors for LP4 and SATA power, making it a straightforward upgrade for enhancing your system's connectivity and performance.
Enhanced connectivity
The StarTech.com 4-Port USB-A PCIe Card offers expansive connectivity with four external 9-pin USB Type-A connectors, enabling multiple USB 3.2 Gen 1 device connections for a seamless user experience. -
High-speed data transfer
With a data transfer rate of 5 Gbps, this USB 3.2 Gen 1 interface ensures rapid file transfers, making it ideal for high-bandwidth devices such as external hard drives and HD cameras. -
Reliable power delivery
Features like USB Power Delivery (up to 10 W) and bus-powered capability ensure that connected devices are charged and operate efficiently, without the need for additional power sources. -
Easy installation
The card's Plug-and-Play form factor, designed for PCI Express 2.0 x4 slots, along with internal power connectors for LP4 and SATA power, ensures a hassle-free setup in a wide range of PC configurations.
- StarTech.com 4-Port USB-A PCIe Card, USB 3.2 5Gbps, 4x USB Controllers - USB adapter - PCIe 2.0 x4 - USB 3.2 Gen 1 x 4
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x4
- PCI Specification Revision
- PCIe 2.0
- Ports
- USB 3.2 Gen 1 x 4
- 1.9 cm x 16.9 cm x 12 cm
- 100 g
- Data Link Protocol
- USB 3.2 Gen 1
- Data Transfer Rate
- 5 Gbps
- Processor
- Renesas / Diodes Incorporated UPD720202 / PI7C9X2G608
- USB 3.2 Gen 1
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.31 or later LTS versions only
- 2-year warranty
- Designed For
- P/N: FCREADMICRO3V2, USB315AC1M, USB3S2SAT3CB
- USB adapter
- Form Factor
- Plug-in card
- PCIe 2.0
- Ports
- USB 3.2 Gen 1 x 4
- Connectivity Technology
- Wired
- USB 3.2 Gen 1
- 5 Gbps
- UASP, bus powered, USB Power Delivery (up to 10 watt)
- USB 3.2 Gen 1
Processor / Memory
- Processor
- 4 x USB 3.2 Gen 1 - 9 pin USB Type A - female (external) , 1 x LP4 - 4 pin power - female (internal) , 1 x SATA power - 15 pin Serial ATA power - male (internal)
- Included Accessories
- Low-profile bracket
- WEEE
- Black
- OS Required
- 1.9 cm
- 16.9 cm
- 12 cm
- 100 g
- Shipping Width
- 3.8 cm
- Shipping Depth
- 20.7 cm
- Shipping Height
- 14.4 cm
- Shipping Weight
- 110 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 90% RH (non-condensing)
- Designed For
StarTech.com 4-Port USB-A PCIe Card, 5Gbps
