Connect your USB Type-C devices to your computer. This USB to USB-C cable lets you connect your USB 3.0, USB Type-C devices such as a hard drive, or mobile device to the USB Type-A port on your computer, charger or tablet.
Efficient data transfer
With a data rate of 5 Gbps, this cable enables quick and efficient synchronization between devices, ensuring that large files are transferred without delay. -
Durable construction
The cable features a robust PVC jacket and nickel-plated connectors, which provide protection against wear and tear, making it a lasting solution for daily use. -
Broad compatibility
Equipped with both USB Type-A and USB-C connectors, this cable allows seamless connections with a variety of devices, enhancing its utility across different applications. -
Compliant standards
This cable adheres to USB 3.0 standards and is RoHS and WEEE compliant, ensuring safety and environmental responsibility without sacrificing performance.
- StarTech.com USB to USB C Cable - 1m / 3 ft - 5Gbps - USB A to USB C - USB Type C - USB Cable Male to Male - USB C to USB (USB315AC1M) - USB cable - USB to 24 pin USB-C - 1 m
- USB cable
- Sync and charge, 5 Gbps data rate
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, HBS304A24A, MST30C2HDPPD
- USB cable
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/32
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB 3.0, RoHS, WEEE
- 2-year warranty
- Designed For
StarTech.com 4-Port USB-A PCIe Card, 5Gbps | In Stock | £84.39 |
