Charge and sync your USB 2.0 Micro-B devices from a USB-C host. Need to connect your Micro-USB 2.0 device to a newer USB Type-C laptop or desktop computer? This 1m USB Type-C to Micro-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Charge and sync your older Micro-USB mobile devices, such as your tablet or phone, with newer computers at data transfer rates of up to 480 Mbps.
The cable can also be used to backup data to an external Micro-USB 2.0 hard drive from your USB-C or Thunderbolt 3 computer.
- StarTech.com USB C to Micro USB Cable - 3 ft / 1m - USB 2.0 Cable - Micro USB Cord - Micro B USB C Cable - USB 2.0 Type C (USB2CUB1M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 1 m
- USB-C cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C3A1CFB, HB30C3A1CFS
- USB-C cable
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.72 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.68 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.37 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.11 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.66 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.61 |
StarTech.com 2m USB 2.0 C to Micro B Cable | In Stock | £12.80 |
StarTech.com 0.5m USB 2.0 C Micro-B Cable | In Stock | £8.67 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £18.04 |
