StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M
Quicklinx: 95R7WS00 Mfr#: USBAB1ML
Length: 1m
19 In Stock
£5.00 ex VAT
£6.00 inc VAT
Connect hard-to-reach USB 2.0 peripherals, for installation in narrow spaces. The USBAB1ML 1-meter USB printer cable features one USB-A male connector and one left-angle USB-B male connector, providing a high-quality connection to USB 2.0 peripherals and enabling installation in narrow spaces.
As an alternative, StarTech.com also offers a 1m USB 2.0 A to Right Angle B Cable (USBAB1MR), which provides the same convenience as this left-angled cable, but allows you to connect to your USB device from the opposite direction.
  • Convenient left angle connector
    The left angle connector allows for optimal placement of devices, making it easier to connect in tight areas without the risk of damaging the ports.
  • Stable data transmission
    With its shielded design, this cable ensures stable and reliable data transfer, minimizing the potential for signal loss and interference.
  • Durable construction
    Nickel-plated connectors provide enhanced durability, ensuring that the cable can withstand regular use while maintaining performance quality.
  • Compliant with industry standards
    This cable meets USB 2.0 standards, ensuring compatibility with a wide range of devices and enabling efficient data transfer.
StarTech.com 1m USB 2.0 A to Left Angle B Cable Cord - 1 m USB Printer Cable - Left Angle USB B Cable - 1x USB A (M), 1x USB B (M) (USBAB1ML) - USB cable - USB Type B to USB - 1 m
USB cable
Shielded
Left-angled connector
Length
1 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
1 m
Connector
USB / USB 2.0, RoHS
95R7 StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £19.86
95R7 StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £32.81
95R7 StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.59
95R7 StarTech.com 3M RIGHT ANGLE USB PRINTER In Stock £5.82
95R7 StarTech.com 2m USB 2.0 A to Right Angle B Cable - M/M In Stock £5.20
95R7 StarTech.com 2m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.25
95R7 StarTech.com 1m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.00
95R7 StarTech.com 3m USB 2.0 A to Left Angle B Cable - M/M In Stock £5.43
Length: 1m
