StarTech.com N6PATC1MPL. Cable length: 1 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 42 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
Reliable connectivity
This network cable features gold-plated connectors to enhance signal quality and ensure uninterrupted data transmission. -
Durable design
Constructed with a PVC jacket, the cable is built to withstand wear and tear while maintaining optimal performance. -
Snagless connectors
The innovative snagless design minimizes the chance of cable damage during installation and ensures easy Plug-and-Play connectivity.
- StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Purple, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MPL) - network cable - 1 m - purple
- Network cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Snagless, stranded, PoE ready
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Purple
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 1 m
- 42 g
- Purple
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, WEEE - up to 500 MHz
StarTech.com 1m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.83 |
StarTech.com 1m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.87 |
StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.90 |
StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.89 |
StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.86 |
StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange | In Stock | £3.83 |
