Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC1MWH Cat 6 Patch Cable (1m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Durable construction
The cable is made from high-quality PVC material, providing resistance to wear and tear for long-lasting performance. -
Snagless connectors
The snagless design prevents entanglement and damage to connectors, ensuring reliable connections during installation. -
High-speed capability
With a CAT6 rating, this cable supports fast data transfer rates suitable for demanding applications. -
Gold connectors
Gold plating on the connectors ensures better conductivity and reduces interference, enhancing overall signal quality. -
Reliable compatibility
Equipped with male RJ-45 connectors on both ends, this cable is compatible with a wide range of networking equipment.
- StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MWH) - patch cable - 1 m - white
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Snagless
- Length
- 1 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL
StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.08 |
StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.96 |
StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.08 |
StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M red | In Stock | £4.06 |
StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange | In Stock | £4.06 |
StarTech.com 1m Purple Cat6 Patch Cable | In Stock | £4.06 |
