Charge or sync micro USB mobile devices from a standard USB port on your desktop or mobile computer. The UUSBHAUB1M 1-meter USB-A to Micro USB cable features one USB 'A' male connector, and one 'Micro-B' male connector, providing a high quality connection between USB 2.0 mobile devices that use a Micro USB connector (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems) and a USB-capable computer for everyday tasks such as data synchronization and file transfers.
Durable construction
This Micro USB cable features nickel-plated connectors that resist corrosion and wear, ensuring a long-lasting connection. -
Versatile compatibility
Designed with a 4-pin USB Type-A and a 5-pin Micro-USB Type-B connector, this cable is compatible with a wide range of devices.
- StarTech.com 1m Micro USB Cable A to Micro B - USB cable - USB to Micro-USB Type B - 1 m
- USB cable
- Technology
- Shielded
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com 1m Micro USB Cable - A to Micro B | In Stock | £5.73 |
StarTech.com 2m Micro USB Cable - A to Micro B | In Stock | £6.09 |
StarTech.com 0.5m Micro USB Cable A to Micro B | In Stock | £2.42 |
StarTech.com 3m Micro USB Cable M/M - USB A to Micro B | In Stock | £6.32 |
