Charge or sync Micro USB mobile devices from a standard USB port on your desktop or mobile computer.
The UUSBHAUB3M USB-A to Micro-B Cable (3m) provides a high quality connection between Micro USB-equipped USB 2.0 mobile devices (such as BlackBerry or Android-based smart phones, digital cameras, PDAs, Tablet PC devices and GPS systems) and a USB-capable computer, for everyday tasks such as data synchronization and file transfers.
Durable construction
The cable features a braided design that provides enhanced durability, allowing it to withstand regular use without fraying or breaking. -
Reliable data transfer
This USB cable supports USB 2.0 standards, ensuring stable and efficient data transfer for compatible devices. -
Flexible connectivity
Equipped with a 4-pin USB Type-A connector and a 5-pin Micro-USB Type-B connector, this cable offers versatile compatibility with multiple devices.
- StarTech.com 3m Micro USB Cable M/M USB A to Micro B - USB cable - USB to Micro-USB Type B - 3 m
- USB cable
- Technology
- Shielded
- Braided
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: KITBXAVHDPEU, KITBXAVHDPUK
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Braided
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 1m Micro USB Cable - A to Micro B | In Stock | £5.56 |
StarTech.com 2m Micro USB Cable - A to Micro B | In Stock | £5.89 |
StarTech.com 0.5m Micro USB Cable A to Micro B | In Stock | £5.16 |
StarTech.com 3m Micro USB Cable M/M - USB A to Micro B | In Stock | £6.62 |
