StarTech.com 1m Lightning USB C Micro-B Cbl
Quicklinx: CZCCWS00 Mfr#: LTCUB1MGR
Length: 1m
Colours:
45 in stock
£19.91 ex VAT
£23.89 inc VAT
Charge or sync your Apple Lightning, USB Type-C, or Micro-USB mobile device using a single cable. This convenient USB multi-charger cable lets you charge and sync your Apple Lightning equipped devices, or your Android mobile devices, through a USB port on your laptop.
Offering a Lightning connector for your iPhone or iPad, a USB-C connector for your newer phone or tablet and a Micro-USB connector for your older mobile devices, it's the ideal cable for all of your mobile charging needs.
The 3-in-1 charging cable eliminates the need to carry multiple cables for all of your mobile devices.
You can also use the cable to charge your devices from a USB wall charger, car charger or power bank - great for people on the move, for providing simple, tidy connections.
With multiple connections available to you, this USB charging cable is perfect for leaving in your car or at your desk. Keep it connected to your car charger or plugged into your work computer so that when you commute to work or when you arrive in the office you know you're ready to go.
  • Charge and sync your mobile devices while you're on the road
    The 3-in-1 charging cable eliminates the need to carry multiple cables for all of your mobile devices. You can also use the cable to charge your devices from a USB wall charger, car charger or power bank - great for people on the move, for providing simple, tidy connections.
  • Leave one in your car or at your desk
StarTech.com 3.3 ft 1m USB Multi Charging Cable - Lightning USB-C Micro-USB - USB cable - 1 m
USB cable
Braided
Length
1 m
Connectors
4 pin USB Type A - male
Connectors (Second End)
Apple Lightning - male , 24 pin USB-C - male , 5 pin Micro-USB Type B - male
Silver
USB cable
American Wire Gauge (AWG)
22/28
Plated Connector
Nickel
Braided
Length
1 m
Silver
120 g
Connectors
RoHS
CZCC StarTech.com 1m White Micro USB Cable - A to Micro B In Stock £2.91
CZCC StarTech.com 1m Lightning/Dock/Micro USB In Stock £15.17
CZCC StarTech.com Lightning/Micro USB Cable In Stock £17.31
CZCC StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £5.49
CZCC StarTech.com 1m Lightning USB C Micro-B Cbl In Stock £19.91
Length: 1m
Price Range Ex VAT: 0 - 50
