Charge or sync your Micro USB, iPhone, iPod or iPad device using a single cable. Tired of carrying around multiple cables for charging and syncing your different mobile devices?
This convenient 2-in-1 cable lets you charge and sync either your Apple Lightning equipped devices or your Android mobile devices, through an available USB port on your PC or Mac computer.
Offering both a Lightning connector for your iPhone, iPod or iPad and a Micro USB connector for your Android phone or tablet, this is the perfect cable for all your mobile charging needs.
The LTUB1MBK black 2-in-1 charge-and-sync cable is Apple MFi certified.
- StarTech.com 1m (3 ft) Black Apple 8-pin Lightning Connector or Micro USB to USB Combo Cable for iPhone iPod iPad - Charge and Sync Cable (LTUB1MBK) - charging / data cable - Lightning / USB - 1 m
- Cable
- Charging / data cable - Lightning / USB
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 1 m
- Black
- Connectors
- USB - male
- Connectors (Second End)
- Micro-USB Type B - male , Lightning - male
- Designed For
- P/N: ARMTBLTDT, ARMTBLTIW, ARMTBLTUGN, SECTBLTDT, SECTBLTPOS, ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824, STNDTBLT1A5T, STNDTBLT1FS, STNDTBLTMOB
- Cable Type
- Interface Supported
- Lightning / USB
- Technology
- Shielded
- 24/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Black
- Connectors
- 4 pin USB Type A - male
- 5 pin Micro-USB Type B - male , Apple Lightning - male
- MFI
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.14 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £53.10 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £37.96 |
StarTech.com 1m Lightning USB C Micro-B Cbl | In Stock | £24.61 |
