Charge or sync your Micro USB, iPhone, iPod or iPad device using a single cable. Tired of carrying around multiple cables for charging and syncing your different mobile devices?
This convenient 3-in-1 cable lets you charge and sync your Apple Lightning equipped devices, 30-pin Apple devices or your Android mobile devices, through a USB port on your PC or Mac computer.
Offering either a Lightning or 30-pin Dock connector for your iPhone, iPod or iPad and a Micro USB connector for your Android phone or tablet, this is the perfect cable for all your mobile charging needs.
The LTADUB1MB black 3-in-1 charge-and-sync cable is Apple MFi certified.
- StarTech.com 1m 3 ft Black Apple 8-pin Lightning or 30-pin Dock Connector or Micro USB to USB Cable for iPhone iPod iPad - Charge & Sync (LTADUB1MB) - charging / data cable - 1 m
- Cable
- Charging / data cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 1 m
- Black
- Connectors
- Lightning - male , Apple Dock - male , Micro-USB Type B - male
- Connectors (Second End)
- USB - male
- 2-year warranty
- Designed For
- P/N: ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824
- Cable Type
- Technology
- Double shielded
- 24/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Black
- Connectors
- Apple Lightning - male , Apple Dock connector - male , 5 pin Micro-USB Type B - male
- 4 pin USB Type A - male
- RoHS, MFI
- Limited warranty - 2 years
- Designed For
