StarTech.com 1m Lightning USB C Micro-B Cbl
Quicklinx: CZCCWS00 Mfr#: LTCUB1MGR
Length: 1m
Colours:
More than 50 In Stock
£24.01 ex VAT
£28.81 inc VAT
Charge or sync your Apple Lightning, USB Type-C, or Micro-USB mobile device using a single cable. This convenient USB multi-charger cable lets you charge and sync your Apple Lightning equipped devices, or your Android mobile devices, through a USB port on your laptop.
Offering a Lightning connector for your iPhone or iPad, a USB-C connector for your newer phone or tablet and a Micro-USB connector for your older mobile devices, it's the ideal cable for all of your mobile charging needs.
The 3-in-1 charging cable eliminates the need to carry multiple cables for all of your mobile devices.
You can also use the cable to charge your devices from a USB wall charger, car charger or power bank - great for people on the move, for providing simple, tidy connections.
With multiple connections available to you, this USB charging cable is perfect for leaving in your car or at your desk. Keep it connected to your car charger or plugged into your work computer so that when you commute to work or when you arrive in the office you know you're ready to go.
  • 3-in-1 USB Charging Cable
    Keep this USB to Micro-USB, USB-C or Lightning cable on hand for all your charging needs, instead of carrying multiple cables. The 3-in-1 cable makes it easy for you to switch between different device models and platforms. Note that it will only connect to one device at a time. Charge your devices from a USB wall charger, car charger, or power bank. The longer cable offers a greater range, so you can access your device conveniently even while it's connected to a charger.
  • Avoid Kinks and Tangles
    With a braided nylon jacket, this durable charging cable doesn't kink or tangle as easily as non-braided cables do. It's an excellent replacement for any of your charging cables.
  • Easy to Use
    To charge or sync a USB-C or Lightning mobile device, simply attach the corresponding connector to the Micro-USB connector and plug into your device. To charge or sync a Micro-USB device, plug just the middle connector of the cable into your mobile device. The cable will only charge or sync one device at a time. LTCUB1MGR is Apple MFi certified and backed by StarTech.com 2-year warranty to ensure dependable performance.
StarTech.com USB Multi Charging Cable - 3.3 ft / 1m - Lightning / USB-C / Micro-USB - Braided - MFi Certified - USB 2.0 - 3 in 1 Charging (LTCUB1MGR) - USB cable - 1 m
USB cable
Braided
Length
1 m
Connectors
4 pin USB Type A - male
Connectors (Second End)
Apple Lightning - male , 24 pin USB-C - male , 5 pin Micro-USB Type B - male
Silver
USB cable
American Wire Gauge (AWG)
22/28
Plated Connector
Nickel
Braided
Length
1 m
Silver
120 g
Connectors
RoHS
CZCC StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.00
CZCC StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £8.64
CZCC StarTech.com 1m Lightning USB C Micro-B Cbl In Stock £24.01
Length: 1m
