StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9J4ZWS00 Mfr#: N6PATC1MGN
Length: 1m
Colour: Green
16 In Stock
£3.90 ex VAT
£4.68 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC1MGN Cat 6 Patch Cable (1m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Durable Construction
    This Ethernet cable features a PVC jacket material that ensures longevity and protection against wear and tear, suitable for both home and office use.
  • Gold-Plated Connectors
    Equipped with male RJ-45 connectors that are gold-plated, this cable helps enhance conductivity and reduce corrosion, ensuring a stable connection.
  • Effective Performance
    With a wiring scheme of T568B and 4 pairs per cable, this CAT6 Ethernet cable is designed to deliver optimal speed and connection reliability.
StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MGN) - patch cable - 1 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL
9J4Z StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.90
9J4Z StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.89
9J4Z StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.86
9J4Z StarTech.com 1m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.81
9J4Z StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M red In Stock £3.86
9J4Z StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange In Stock £3.83
9J4Z StarTech.com 1m Purple Cat6 Patch Cable In Stock £3.88
Length: 1m
Colour: Green
