StarTech.com 1m Gray Cat6a Cable STP
Quicklinx: CZBQWS00 Mfr#: 6ASPAT1MGR
Length: 1m
Colour: Grey
£10.31 ex VAT
£12.37 inc VAT
Deliver high-performance 10 Gigabit network connections, free of noise and EMI/RFI interference. This Cat6a cable meets or exceeds all Category 6a cable specifications to ensure reliable 10Gb network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
This 1-meter gray patch cable is perfect for standard applications such as connecting from a wall jack to your laptop docking station or desktop computer.
For easier network installations, our Cat6a patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
Each cable is tested for up to 500MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Constructed with 100% copper and foil-shielded, twisted-pair wiring, this cable was built for quality performance. The cable is designed to keep the data signals traveling through your network free from interference and is perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
  • Reliable shielding
    The aluminum-polyester foil shielding effectively reduces interference, ensuring that data is transmitted clearly and reliably across the network.
  • Enhanced durability
    Featuring a robust PVC jacket, this patch cable is designed to withstand everyday wear and tear, making it suitable for both home and professional environments.
  • Versatile connectivity
    With male RJ-45 connectors on both ends, this cable is compatible with a wide range of networking devices, ensuring flexible connectivity options.
  • PoE capability
    The cable supports Power over Ethernet, allowing it to deliver power to compatible devices while facilitating data transfer, streamlining installation.
  • High performance
    Tested for frequencies up to 500 MHz, this cable ensures optimal performance for high-speed data applications, making it ideal for modern networking needs.
StarTech.com 1m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT1MGR) - patch cable - 1 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 500 MHz
CZBQ StarTech.com 1m Black Cat6a Cable STP In Stock £9.91
Length: 1m
Colour: Grey
