StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 7RPRWS00 Mfr#: DISPL1M
Type: DisplayPort
Length: 1m
More than 50 In Stock
£10.20 ex VAT
£12.24 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort -equipped devices. The DISPL1M 1m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
  • Durable shielding
    The cable features aluminum mylar foil with braid shielding that minimizes signal interference and provides reliable performance.
  • Secure latching connectors
    Equipped with latches on both male connectors, this cable ensures a stable connection to your devices, preventing accidental disconnections.
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M DisplayPort 4k - DisplayPort cable - 1 m
DisplayPort cable
Shielded
Latched
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
1 m
Connector
20 pin DisplayPort - male
RoHS
7RPR StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.07
7RPR StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £26.25
7RPR StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £12.37
7RPR StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.20
7RPR StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £22.80
7RPR StarTech.com 7m DisplayPort Cable with Latches - M/M In Stock £59.32
Type: DisplayPort
Length: 1m
