Power your USB Type-C devices. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
Fast-charge your mobile devices
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road. -
Provide superior connections with USB-IF certified cables
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices. The USB2C5C1M from StarTech.com is backed by a 2-year warranty for guaranteed reliability.
- StarTech.com USB C To USB C Cable - 3 ft / 1m - USB-IF Certified - 5A PD - USB 2.0 - USB Type C Charging Cable - USB C Fast Charge Cable (USB2C5C1M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Technology
- Double shielded
- Up to 100 Watts of power delivery
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Current
- 5 A
- Thunderbolt 3 / USB 2.0
- Black
- 2-year warranty
- USB-C cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/26
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- 45 g
- Connector
- Thunderbolt 3 / USB 2.0, RoHS, USB-IF, WEEE
- 2-year warranty
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £17.50 |
StarTech.com 3m 10ft USB C Cable w/ 5A PD | In Stock | £19.10 |
StarTech.com 1m 3ft USB C Cable w/ 5A PD | In Stock | £11.39 |
StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m | In Stock | £15.89 |
StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable | In Stock | £13.94 |
StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M | In Stock | £15.47 |
StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M | In Stock | £10.19 |
