StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable
Quicklinx: D9V8WS00 Mfr#: QSFPH40GCU1M
Length: 1m
Colour: Black
£75.66 ex VAT
£90.79 inc VAT
Connect your Cisco 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-CU1M Compatible 1m 40G QSFP+ to QSFP+ DAC Twinax, 40GbE QSFP+ Copper DAC 40 Gbps/40GE Low Power Passive QSFP+ Transceiver Module DAC, Cisco Firepower C9200 - Lifetime Warranty (QSFPH40GCU1M) - 40GBase direct attach cable - 1 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Passive cable
Length
1 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
1 m
72 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 1m
Colour: Black
