StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable
Quicklinx: D9THWS00 Mfr#: QFXQSFPDAC1M
Length: 1m
Colour: Black
Select:
10 In Stock
£20.95 ex VAT
£25.14 inc VAT
Connect your Juniper 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
The QFXQSFPDAC1M is a reliable replacement cable for the Juniper Networks EX-QSFP-40GE-DAC50CM.
StarTech.com Juniper QFX-QSFP-DAC-1M Compatible 1m 40G QSFP+ to QSFP+ Direct Attach Cable Twinax, 40GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, 40GE QSFP+ Cable - Lifetime Warranty (QFXQSFPDAC1M) - direct attach cable - 1 m - black
Direct attach cable - SFF-8436
Twinaxial
Shielding Material
Copper
Passive cable, Hot-pluggable
Length
1 m
Connector
QSFP+
Connector (Second End)
QSFP+
Network Cable Type
Twinaxial
Shielding Material
Copper
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Length
1 m
1.8 cm
1.3 cm
72 g
Connector
QSFP+
QSFP+
FCC, RoHS, WEEE, MSA, RCM
70 °C
D9TH StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable In Stock £20.95
Length: 1m
Colour: Black
