StarTech.com 1m 3.3ft 10G SFP+ DAC Cable
Quicklinx: D9T7WS00 Mfr#: J9281BST
Length: 1m
Colour: Black
Select:
10 In Stock
£33.71 ex VAT
£40.45 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com HPE J9281B Compatible 1m 10G SFP+ to SFP+ DAC Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC Firepower 1040, 10 Gbps SFP+ Cable - Lifetime Warranty (J9281BST) - 10GBase direct attach cable - 1 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
1 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP J9281B
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
1 m
72 g
Connector
SFP+ - latched
SFP+ - latched
HP J9281B
FCC, RoHS, MSA
70 °C
D9T7 StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £33.71
D9T7 StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £44.55
D9T7 StarTech.com 7m 23ft 10G SFP+ DAC Cable In Stock £57.84
D9T7 StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable In Stock £24.63
D9T7 StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £34.56
D9T7 StarTech.com 5m 16.4ft 10G SFP+ DAC Cable In Stock £41.18
Length: 1m
Colour: Black
