StarTech.com 7m 23ft 10G SFP+ DAC Cable
Quicklinx: D9T9WS00 Mfr#: J9285BST
Length: 7m
Colour: Black
Select:
Hurry, only 1 left in stock!
£56.65 ex VAT
£67.98 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting applications such as point-to-point across-rack network switch or server connections.
  • Reliable passive design
    This cable is designed as a passive solution, optimizing performance for short connections while maintaining power efficiency.
  • Robust environmental tolerance
    The cable functions well in a range of temperatures, making it suitable for both indoor and outdoor applications.
  • Secure latched connections
    With latched SFP+ connectors, this cable ensures a secure fit to prevent accidental disconnections.
  • Durable PVC jacket
    The cable is protected by a PVC jacket, providing resistance against wear and tear in various environments.
  • Standard-compliant construction
    The cable complies with FCC, RoHS, and MSA standards, ensuring safety and reliability for network use.
StarTech.com HPE J9285B Compatible 7m 10G SFP+ to SFP+ DAC Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC Firepower 1040, 10 Gbps SFP+ Cable - Lifetime Warranty (J9285BST) - 10GBase direct attach cable - 7 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
7 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP J9285B
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Passive cable
Length
7 m
450 g
Connector
SFP+ - latched
SFP+ - latched
HP J9285B
FCC, RoHS, MSA
70 °C
D9T9 StarTech.com 1m 3.3ft 10G SFP+ DAC Cable In Stock £33.41
D9T9 StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £43.55
D9T9 StarTech.com 7m 23ft 10G SFP+ DAC Cable In Stock £56.65
D9T9 StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable In Stock £24.04
D9T9 StarTech.com 3m 9.8ft 10G SFP+ DAC Cable In Stock £33.70
D9T9 StarTech.com 5m 16.4ft 10G SFP+ DAC Cable In Stock £40.34
Length: 7m
Colour: Black
